How To's Show us what ya did and how ya did it!
Replacing the Stator damper/ starter clutch
Old Jun 10, 2009 | 12:44 PM
Shadow's Avatar
Default Replacing the Stator damper/ starter clutch
Thanks to all who contributed to this excellent how to by Stu
http://www.stu.co.nz/cbr1000fix/
Old Oct 8, 2009 | 10:53 PM
Shadow's Avatar
Stu's link is back !!!
Old Mar 11, 2011 | 03:57 AM
gms-composites's Avatar
Exclamation Starter clutch
I would like to say THANK YOU for this post. My problem is gone, and season can begin. Regards Peter
Old Mar 22, 2011 | 03:25 PM
AndyW's Avatar
Smile Replacing Alternator Damper/Chain adjuster
Have just joined this forum after buying a CBR1000F with this starting problem as described by Stu.
Now I've removed all the necessary parts and I'm waiting for the new damper to arrive. I have a problem though, having an inquisitive mind I moved the bottom chain adjuster up the ratchet made a couple of clicks and is now holding the tensioner too close and I fear I won't be able to fit the new damper.
Can the tensioner be slackened off from the alternator opening or will I have to split the cases?
Any advice would be appreciated.
I love the site and all the posts helping riders like me out. Thanks
Andy
Old Mar 22, 2011 | 08:24 PM
Sprock's Avatar
Not quite sure but I reckon there must be a way to disengage the ratchet somehow
Who wants to have to crack her open ever !
Here's some more required reading from our own HenryM pm him I'm sure
he'll have the answer and he's a really good and knowledgeable Guy
LINK
Old Apr 22, 2013 | 05:30 PM
Butthead1000's Avatar
Default tensioner release
It is possible, It requires the removal of the oil pump, and can be done with the engine installed. After removing the oil pump you can access the tab on the tensioner to release the rachet (I used a long Snap-On cotter pin remover). Yeah, it sucks lay'in on your back, but I think it's a lot better than pulling the engine and splitting cases.
Old Apr 22, 2013 | 07:48 PM
Sebastionbear1's Avatar
I did it without even removing the pump. I bent some wire, poked it in from the starter hole over the alternator chain and down to the ratchet pawl. Left it in there while I reassembled the alternator shaft in, tightened everything then pulled it out!
Cheers, SB
