-   How To's (https://cbrforum.com/forum/how-tos-81/)
-   -   Make Your Own Steering Stem Nut Socket!! (https://cbrforum.com/forum/how-tos-81/make-your-own-steering-stem-nut-socket-114367/)
malbojah Jul 26, 2010 04:27 PM
So not wanting to pay $90+ dollars for a tool that only will work on my CBR, I decided to fab up my own tool.
Stuff you need:
36mm socket
1 1/4" - 1 1/2" steel pipe
Angle grinder
Welder (or beer for the friend with the welder)
masking tape
fine point market
I'm going to assume you know how to take the upper triple tree off, so I'll skip all that stuff.
Step Uno: Find a socket
Sears sells them for about $9
http://img507.imageshack.us/img507/3139/dscf0101q.jpg
Step Dos: Grind the crown down
Need a flat surface to work with
http://img837.imageshack.us/img837/113/dscf0105.jpg
Step Three (that's it for my spanish) Mark the socket
Line it up
http://img507.imageshack.us/img507/3553/dscf0106t.jpg
Then mark it with the marker
http://img837.imageshack.us/img837/8449/dscf0107.jpg
Step Four
Start Grinding away
Break out the angle grinder and cut out everything but the marked areas
http://img408.imageshack.us/img408/7896/dscf0108hx.jpg
http://img837.imageshack.us/img837/762/dscf0109.jpg
You're going to have to back-cut the tabs so they slide into the nut
http://img831.imageshack.us/img831/5953/dscf0110h.jpg
Step Five
Wrap with tape
I tried with electrical tape, but couldn't get consistent results (stretched and distorted too easily)
http://img831.imageshack.us/img831/6144/dscf0114.jpg
so I grabbed some painters tape (1 1/2") and it worked perfectly (NO PICTURE, just wrap from base of socket).
Draw a line around the socket using the tape as a guide, then peel off tape
http://a.imageshack.us/img412/4149/dscf0115o.jpg
Step Six Break out that angle grinder again
And cut the socket in half
http://img843.imageshack.us/img843/2905/dscf0116.jpg
http://a.imageshack.us/img299/874/dscf0117h.jpg
Step Seven Cut a spacer
I had some pipe laying around as a cheater bar and it lined up...... close enough to use as a spacer
http://img831.imageshack.us/img831/4030/dscf0120u.jpg
I figure I needed about an inch of metal
http://a.imageshack.us/img408/446/dscf0119l.jpg
So I just used the painters tape again
http://a.imageshack.us/img594/5883/dscf0121.jpg
Again mark...
http://img831.imageshack.us/img831/9228/dscf0122.jpg
Then cut..
http://a.imageshack.us/img412/2873/dscf0123y.jpg
and you'll have a spacer
http://a.imageshack.us/img412/2401/dscf0124d.jpg
http://imageshack.us/a/img507/3785/dscf0126d.jpg
malbojah Jul 26, 2010 05:22 PM
Step Nine WELDING TIME!!!
Tack the bottom
http://a.imageshack.us/img594/4940/dscf0127a.jpg
Sorry it looks like crap, it's from a free welder that only has flux core wire. I'll convert it to gas when I run out of wire.
Run a good bead along the edge, then clean it up
http://img831.imageshack.us/img831/5125/dscf0128.jpg
Put the top on, tack it in place, flip the whole thing over, then run a bead (I flipped it so I wouldn't be welding from a weird angle)
http://img831.imageshack.us/img831/6316/dscf0129.jpg
And it fits like a champ
http://img843.imageshack.us/img843/1360/dscf0130.jpg
http://img530.imageshack.us/img530/449/dscf0131o.jpg
Now you may be asking, "hey, why don't I just use the 36mm, grind the tabs out then use it like that?"
Well the answer it because the stem sticks up too far
http://img299.imageshack.us/img299/610/dscf0104yw.jpg
And you're not going to be able to drill out the center of the socket (already tried)
Sprock Aug 1, 2010 09:13 PM
Nice write up.
There's another option too ...... a little bit lower tech :)
http://www.gadgetjq.com/mm_fork_nut_tool.jpg
malbojah Aug 1, 2010 10:35 PM
Originally Posted by Sprock (Post 952911)
Nice write up.
The only problem I see with that is you can't put a torque wrench on it
Sprock Aug 4, 2010 12:45 PM
I'm a gifted torquer :)
grendl Sep 26, 2010 12:41 PM
Sprock,
That is absolutely brilliant man ! The first of the thread is excellent too, but you have brought it down to where this can be done without the welding and such. Congrats to both, but the cresent wrench idea...dude !
HenryM May 5, 2011 04:16 PM
I never caught this thread.
Malbo, excellent work.
Sprock, you cheap bastard!
That must have been one hell of a discount wrench if you could drill through it. D'ja get it out of a Christmas cracker?
Gifted torquer? Y'd bloody need to be..... but for the wrong reason.
Can I borrow your socket Malbo. Think my head bearings need changing soon. Some vibration and rattle starting to make its self known.
Sprock May 5, 2011 04:45 PM
Om not cheap just not as gifted as Malbo :)
You could say I know the drill. Henry stop riding with your knees out
then the rattling will stop !
malbojah May 5, 2011 07:39 PM
Honestly, for the price of cross shipping, it must be cheaper for you to just buy one?
MadHattr059 Aug 31, 2011 06:26 PM
I just used a pipe wrench and torqued it to snug, checking the turning restistance of
the triple-tree till it felt right. Close enough , sez me. ;-)
Ern
