How To's Show us what ya did and how ya did it!
Make Your Own Steering Stem Nut Socket!!
Old Jul 26, 2010 | 04:27 PM
malbojah's Avatar
Default Make Your Own Steering Stem Nut Socket!!
So not wanting to pay $90+ dollars for a tool that only will work on my CBR, I decided to fab up my own tool.
Stuff you need:
36mm socket
1 1/4" - 1 1/2" steel pipe
Angle grinder
Welder (or beer for the friend with the welder)
masking tape
fine point market
I'm going to assume you know how to take the upper triple tree off, so I'll skip all that stuff.
Step Uno: Find a socket
Sears sells them for about $9
Step Dos: Grind the crown down
Need a flat surface to work with
Step Three (that's it for my spanish) Mark the socket
Line it up
Then mark it with the marker
Step Four
Start Grinding away
Break out the angle grinder and cut out everything but the marked areas
You're going to have to back-cut the tabs so they slide into the nut
Step Five
Wrap with tape
I tried with electrical tape, but couldn't get consistent results (stretched and distorted too easily)
so I grabbed some painters tape (1 1/2") and it worked perfectly (NO PICTURE, just wrap from base of socket).
Draw a line around the socket using the tape as a guide, then peel off tape
Step Six Break out that angle grinder again
And cut the socket in half
Step Seven Cut a spacer
I had some pipe laying around as a cheater bar and it lined up...... close enough to use as a spacer
I figure I needed about an inch of metal
So I just used the painters tape again
Again mark...
Then cut..
and you'll have a spacer
Old Jul 26, 2010 | 05:22 PM
malbojah's Avatar
Step Nine WELDING TIME!!!
Tack the bottom
Sorry it looks like crap, it's from a free welder that only has flux core wire. I'll convert it to gas when I run out of wire.
Run a good bead along the edge, then clean it up
Put the top on, tack it in place, flip the whole thing over, then run a bead (I flipped it so I wouldn't be welding from a weird angle)
And it fits like a champ
Now you may be asking, "hey, why don't I just use the 36mm, grind the tabs out then use it like that?"
Well the answer it because the stem sticks up too far
And you're not going to be able to drill out the center of the socket (already tried)
Old Aug 1, 2010 | 09:13 PM
Sprock's Avatar
Nice write up.
There's another option too ...... a little bit lower tech
Old Aug 1, 2010 | 10:35 PM
malbojah's Avatar
Originally Posted by Sprock
Nice write up.
The only problem I see with that is you can't put a torque wrench on it
Old Aug 4, 2010 | 12:45 PM
Sprock's Avatar
I'm a gifted torquer
Old Sep 26, 2010 | 12:41 PM
grendl's Avatar
Thumbs up
Sprock,
That is absolutely brilliant man ! The first of the thread is excellent too, but you have brought it down to where this can be done without the welding and such. Congrats to both, but the cresent wrench idea...dude !
Old May 5, 2011 | 04:16 PM
HenryM's Avatar
I never caught this thread.
Malbo, excellent work.
Sprock, you cheap bastard!
That must have been one hell of a discount wrench if you could drill through it. D'ja get it out of a Christmas cracker?
Gifted torquer? Y'd bloody need to be..... but for the wrong reason.
Can I borrow your socket Malbo. Think my head bearings need changing soon. Some vibration and rattle starting to make its self known.
Old May 5, 2011 | 04:45 PM
Sprock's Avatar
Om not cheap just not as gifted as Malbo
You could say I know the drill. Henry stop riding with your knees out
then the rattling will stop !
Old May 5, 2011 | 07:39 PM
malbojah's Avatar
Honestly, for the price of cross shipping, it must be cheaper for you to just buy one?
Old Aug 31, 2011 | 06:26 PM
MadHattr059's Avatar
I just used a pipe wrench and torqued it to snug, checking the turning restistance of
the triple-tree till it felt right. Close enough , sez me. ;-)
Ern
