How To's Show us what ya did and how ya did it!
How to Replace your Grips
Old Jun 3, 2010 | 08:46 PM
kilgoretrout's Avatar
Administrator - Retired
Default How to Replace your Grips
When I replaced my old stock grips with some nice new Gel Pro-Grips, I decided to make a little video showing how to use compressed air to remove the old stockers. Apparently, many people either don't think to use compressed air, or don't know how to do it. It's definitely the easiest way to do this job.
Considering that a good set of Gel grips are only like $14, it's well worth the cost and a half hour of work. I was surprised at how much less fatigued my hands got after a long day with the gels over the stock ones.
So instead of struggling for an hour and then cutting the old grips off, try this!
(Oh, and don't mind my rambling.... I'd been drinking a bit.... )
http://www.youtube.com/watch?v=GahQTTdPv4o
Old Jun 4, 2010 | 01:05 AM
Shadow's Avatar
Nice one, Dylan.
Old Jun 4, 2010 | 02:14 AM
Bordo's Avatar
Nice job mate although anytime I take off old ones I just run a utility knife down it and they fall off. Takes a few seconds.
Old Jun 4, 2010 | 06:38 AM
wolfman 1000's Avatar
Good idea but not every body has a compressor at home. Another easy way is slide a small flat srew driver in the end and squirt the old multitool (WD40) in therr and they slide straight off. Does the same job and just about every one has a can.
Old Jun 4, 2010 | 10:33 PM
Sprock's Avatar
Yeah ....... good vid Dylan........my audio for some reason kept going to "mute" ..lol
Old Jun 4, 2010 | 10:59 PM
John Cu's Avatar
I just change my stock ones, BUT it seems to be a little larger cause it makes my accelerator to be slower. Now i have to put some washers to the bar end bolts to make it push less the grip. By the way i bought Givi's. Hope you understand me...
Old Jun 5, 2010 | 10:35 AM
You should really look into getting one. They are pretty convenient for air tools and valuable for setting pressure in tires/inflating your new ones. They can usually be found for pretty cheap second hand.
And Bordo, yeah.. I mentioned cutting them off, too. That's what many people do. I like the speed and ease of using air, tho, and some people like to keep the grips that they remove, too. (for whatever reason)
Nice one, Dylan.
Thanks, Pete!
Old Jun 29, 2010 | 04:56 PM
Sprock's Avatar
Gonna be doing this at the weekend ..... same grips Trout .... Pro Grips 917's
like ya recommended ...... they checked out good enough for me when I
saw yours that time. All black ....plain and simple.
Old Jul 2, 2010 | 06:26 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
That is a real neat trick, guess what i am buying this weekend...
Aussie Johnno
Old Jul 2, 2010 | 07:30 AM
regener8ed's Avatar
thanks for the vid, trouts. we needed one on that topic.
