-   How To's (https://cbrforum.com/forum/how-tos-81/)
-   -   fuel pump repair (https://cbrforum.com/forum/how-tos-81/fuel-pump-repair-147724/)
wheelnut Jun 28, 2013 06:53 AM
fuel pump repair
11 Attachment(s)
not sure if this has been covered before.
here goes
first remove side pannel to get to the fuel pump.
turn off fuel and ignition
unplug fuel pump and remove the fuel lines
unclip and remove pump
Attachment 32342
remove rubber casing
Attachment 32343
unscrew single screw in plastic cap and remove
Attachment 32344
place new contacts out and check where everything goes
Attachment 32345
get your soldering iron and unsolder the black wire attached to the contacts
Attachment 32346
remove the 2 screws that hold the contacts on
Attachment 32347
remove the contacts
Attachment 32348
replace with new contacts, noting which wire goes to which screw
Attachment 32349
re-solder black wire to contacts
Attachment 32350
replace plastic cap and rubber sleeve
Attachment 32351
re-join all the pipe work
Attachment 32352
put back on the bike and hopefully it will all work :icon_banana::icon_banana:
