How To's Show us what ya did and how ya did it!
90cbr1000f vacuum diagram?
Old 07-16-2009, 04:29 PM
90cbr1000f's Avatar
Default 90cbr1000f vacuum diagram?
ok so i just bought this bike and the vacuum lines look all messed up and all over the place so i am trying to replace and reorganize them so the bike will run right and im curious if anyone has either pics of the way it should look or a detailed diagram of it... thank you and i look forward to hearing from you...
scotty
Old 07-17-2009, 05:32 AM
Naga_Thai's Avatar
Hi scotty - Here is a start..
  1. Download workshop manual from below.
  2. Which vacuum tubes you referring to? Petlock picture attached...
  3. Attached photo shows..
    YELLOW - tank fuel gauge cable cover sheath.
    GREEN - Pet lock vacuum hose..
  4. Note if you have "Californian" model it has a lot of other "plumbing" - do search this group for that model.
  5. Look here to see other vent pipes & vacuum pipes ....CARB SYNC BALANCE - HOW TO - http://tinyurl.com/6qgfnv & http://tinyurl.com/4o2542
NOTE - 3 completely different configurations
  1. Pre 1990
  2. 1990 to 1993
  3. 1993 0nwards.
Plus the Californian environmental config as an addition.
Old 08-10-2009, 07:06 PM
90cbr1000f's Avatar
ok is there a vacuum diagram for the california model cbr's??? i just got everything off after the bike deciced to quit working on me and i noticed i have tubes running to the ports where you performed your carb syncing.... those 4 tubes then run to 1 large tube that runs under the nose fairing... then also i noticed on the bottom of cylinder 3 (3rd from left that is) there is a brass nipple that was not connected to anything... i would love to get this figured out and as soon as my camera battery is charged i will be taking pics for reference... thanks...
Old 08-12-2009, 10:04 AM
90cbr1000f's Avatar
ok here is a couple pics of the brass nipple that is on the third cylinder that i need to know if it is a vacuum line or somthing else or if i can just cap it off... please let me know asap if you know the answer thanks...
Attached Thumbnails 90cbr1000f vacuum diagram?-brassnipple1edit.jpg   90cbr1000f vacuum diagram?-brassnipple2edit.jpg   90cbr1000f vacuum diagram?-brassnipple3edit.jpg
Old 08-12-2009, 06:28 PM
Naga_Thai's Avatar
Quick reply - I dont know the answer to your question - here are pics I got from somebodys other post - the plumbing might help.
Attached Thumbnails 90cbr1000f vacuum diagram?-honda-cbr1000f-carbs.jpg   90cbr1000f vacuum diagram?-honda-cbr1000f-carbs2.jpg
Old 07-31-2013, 04:12 AM
shures's Avatar
New Member
Why can't i see attached pictures? I need vacuum diagram very much.
Ls1Mx5
10-25-2022 09:40 AM
95Cbr6
03-17-2020 06:34 PM
goldnnght19
09-15-2008 04:35 AM
ssweetbro
03-18-2008 07:13 PM
95Cbr6
03-10-2008 07:36 PM
Quick Reply: 90cbr1000f vacuum diagram?
