Onarom Originals:
1 Attachment(s)
Here are some of the things that I have done that might be usefull to you:
One of my first purchases was a fluke that worked out way better than I ever intended. I happen to buy a "Switch-a-bit" screwdriver from Home Depot and as luck would have it, it is a PERFECT fit under my seat. It literally clips in. Well worth the $15 (also check Sears and Amazon.com) Attachment 72460 The cool thing about this is it is the revolver of screwdrivers. I even replaced one of the slots with an allen-head for removing my fairing bolts. I can't tell you how many times I have used this. I did have to trim one small section of my rear seat, but I haven't had any problems (I have over 14,000 miles on my bike) and it has never moved out of place. http://i174.photobucket.com/albums/w...3/IMG_4040.jpg http://i174.photobucket.com/albums/w...3/IMG_4047.jpg (more "originals" to follow very soon) |
RE: Onarom Originals:
In that last photo, you might have noticed the cable...
It is a master lock "python" cable. Cheap and stores easily under the back seat. http://i174.photobucket.com/albums/w...3/IMG_4024.jpg Once again, I was lucky to find out that I could loosen the bracket under my rear seat, slid the end cap of the cable under the bracket, and thighten the bracket back down. That cable isn't going anywhere! http://i174.photobucket.com/albums/w...3/IMG_4032.jpg I have even used this to lock my bike to a nearby tree. It has a pretty good distance to it (about 5 feet). Here is a photo of it wrapped around my wrist: http://i174.photobucket.com/albums/w...3/IMG_4037.jpg |
Now you might have lso noticed that little notch cut out of that metal loop under my rear seat. That is a very simply mod with a dremel tool that allows you to lock your helmet under your rear seat. Works great!
https://cbrforum.com/upfiles/10702/6...7D18B65AB3.jpg |
Want to tint your headlights or make that silver swing-arm have a unique look?
Try using some of this: https://cbrforum.com/upfiles/10702/F...67B103722E.jpg To create this blacked-out headlight look: https://cbrforum.com/upfiles/10702/8...C033A3EAC8.jpg Or this look on your silver swingarm: https://cbrforum.com/upfiles/10702/0...E2A089C7B8.jpg More info: <UPDATED-click here> |
1 Attachment(s)
Black spray-paint has done okay, but I am looking forward to getting my rear-sets powder coated. However, I am shocked at how well the carbon fiber decal has held up on my heel guards:
Attachment 72459 Not bad for $7 at the local automotive store! I also like how it formed concave bubbles in the holes of the guards. |
Some of you have read my link to create angel eyes (not an "Onarom Original"), but now I wan to make a change.
I didn't think a 2 LED ring was bright enough, so I have finished with a small test prototype using VERY small LEDs on the back of the rod and here is the comparison: http://i174.photobucket.com/albums/w...3/IMG_4079.jpg The bottom set is my trial version. The top represents the old style. I know the new version looks like 3 miniature lights in each row, but it isn't. Here is what it looks like on back: http://i174.photobucket.com/albums/w...3/IMG_4100.jpg Also notice how bright the light is on my thumb and compare it to the "old" version below: http://i174.photobucket.com/albums/w...3/IMG_4102.jpg I don't know if I will really have the patience to complete this little upgrade, but if I do, you all will be the first to know! |
1 Attachment(s)
Oh yeah, less than $10 at he fabric section of Wal-mart (I never knew one existed before this day, I swear:) let me refinish my ripped seat with a new textured "leather"
Attachment 72458 Pretty easy to do. Heat will help in removing the old staples and an air-powered stapler is ideal, but a regular, heavy duty mechanical one will also work. |
this is a great post!!!
1 Attachment(s)
Thanks!
Also, I am not sure if this is common with 1000RR's or if it is just my bike, but I found that the radiator fluid would sometimes leak onto my lower fairing due to the short breathing hose (and occasional wheelies). Simple fix- just buy an extender coupling from an automotive store and some extra hose, then tuck it away. Attachment 72432 |
Make your own LED strip lights
6 Attachment(s)
How to make your own flexible LED strip:
Attachment 72326 Start by cutting the leads to a shorter length. Remember- you still have to differentiate between the Pos. and Neg. so either leave one a little longer, or color code them (i.e. sharpie on the neg. lead) Attachment 72327 The wires I used had a thick, hard coating, so I used a dremel to cut just until I saw the wire: Attachment 72328 Then I used a heat gun (blow dryer will probably work) to soften the coating on the wire and I slid the LED ends under that coating. Remember, you have to choose one of the wires as Negative and theother as positive- and be consistent. TIP- bend the wire where you are going to insert the LED. Attachment 72329 Once the LED is pushed in all of the way, bend it upward. Attachment 72330 Connect to a powersource as if you were only lighting one LED (you will need to find the appropriate resistor). That's it... Keep in mind that this can have other applications. For example, I used it to light a snake cage that I am building (working progress): Attachment 72331 |
