**NEW** HID INSTALLATION WRITE-UP (for newer style kits) 09-05-07
RE: **NEW** HID INSTALLATION WRITE-UP (for newer style kits) 09-05-07
Blue Fox
Followed your link for the updated newer style install.... hate to say this as I've been following you on this subject since I decided to buy an RR in April. Did you notice the newer super slim ballast model? DOH! looks like they'll both fit in the front lower fairing stay....
Sorry if this is the wrong place to reply.... First post
Yep. I've seen the DDM kits that are available with those new "super mini" ballasts. I think they're going for about $130 bucks. They are small ballasts (both would easily fit on that "shelf") with separate igniters. To be honest, I would have purchased those instead, but I was too late in my finding them. This helps out those people wanting a damn good kit for under $100 shipped.
Not to mention, the way I installed mine, you can't see them, and they're not in the way, so it works out the same.
Thanks for the info regardless.
Wolf
Nice work you took the words right out of my mouth..... I'm guessing yes because Blue Fox is always stressing the point to just order a car set, over a motorcycle set, because the car set comes with both bulbs.
Blue Fox?? Correct
Blue Fox?? Correct
ORIGINAL: Wolf
Nice write up, one question. You say high beam ballast and low beam ballast, are the ballasts different? The ballast are the same right, the high beam light is just aimed higher right?
ORIGINAL: Icyalkn
Wolf
Blue Fox?? Correct
Wolf
Blue Fox?? Correct
Let me know if there is anything else you guys need.
ORIGINAL: ryman546
These will work for 07??
ORIGINAL: ryman546
Ok ok....I'm retarded yes. But would the "ultra slim* kit or whatever help in that situation?
Also are you saying that with the motorcycle kit u would have to order 2 kits vs the one automotive kit?
And yes, the car kit comes with 2 bulbs, 2 ballasts and 2 wiring harnesses. The motorcycle kit would only come with 1 bulb, 1 ballast, and 1 wiring harness. Which means that if you ordered the motorcycle kit (which is just 1 car kit split in half), you would have to order 2 of those, which would end up costing you more than the car kit. This is for that eBay store ONLY.
As for that DDM link I provided, that takes you straight to the mini-ballast kit that comes with 2 bulbs/ballasts.
