need help my bike keeps dying
i have an 06 cbr600rr, and sometime when i pull the clutch in the rpms obviously drop n when they do drop the bike just dies. also occasionally when im coming to a stop the bike drops below the 1500 rpms n then dies. ive also noticed that sometimes when im driving ill have it around 4000 rpms and it starts jerking and it feels like it is loosing power. if any of you have any idea what the problem is i would greatly appreciate the help
Whats the history of the bike? Are you the first owener? Has it sat for any period longer than a month or a few weeks?
+1 on all that.
Replace your air and fuel filters for starters. You're not getting enough of one or the other (most likely fuel). While you're changing the fuel filter, inspect the hoses for blockage. Ensure that fuel flows freely up to the pump, and from the pump to the injectors. Heck, while you;re in there, test your pump and pump relay. |
it was the battery terminals. they were kinda loose. i tightened them and havent had any problem since. but thanks for all the advice
That makes sense. Should've asked what you meant by "dies."
