How to: up the reliability of your Regulator Rectifier
If I was going to do it I'd wire it to a relay that 1) tapped into the license plate light so it's only on when the bike is on and 2) to the battery with a fuse for power and 3) a switch in-line in case you need the fan off for some reason, like when working on the bike.
I've been having some issues with my 03 954 not starting. As a result I've been trying to read through posts talking about possible solutions. I've looked at few that talk about R/Rs and most of them have been on how to modify them to run cooler. From reading the posts I have gathered that these modifications allow for a cooler running R/R which allows it to perform better. But I don't know what exactly the R/R even does and what exactly happens for performance to the bike with the modifications? Are the modifications done for preventative maintenance? Are they even needed or is this just a mod that people do that are geeked out about their rides and like to tinker with them (that would be me-even though I am very much a noob)?
Just as a disclaimer...I know this is a thread for "how to do something" but I figured since I'm still talking about R/Rs that it would be OK. If a moderator feels the need to move this please do so (not that you need my permission).
R/R is a regulator/rectifier. It regulates the current going from the stator to the battery, ensuring that it's not too much or too little. The stator + R/R is the same thing as an alternator in a car. Too much current and things start to cook, too little and things die from lack of power.
Honda is known for having really terrible R/Rs because they oveheat. One good reason they overheat is because Honda places them in spots where they don't get any airflow.
Simple fix (after you've confirmed it is your R/R): replace it with an aftermarket one.
