How To: SpeedoDRD Install
4 Attachment(s)
Okay so this is my first "How To" and I picked a pretty easy one, perhaps that's why there wasn't one before. :icon_shrug:
So I got the SpeedoDRD by 12oclock Labs and installed it on my 96 F3. Attachment 57264 First take off what ever fairings are needed to reach the speed sensor, luckily mine runs along the outside of the frame and was easy to get to. Attachment 57265 Once you find the speed sensor connectors unplug them Attachment 57266 Next plug in the unit Attachment 57267 Once its plugged in, turn on the bike. I would suggest making it some what dark as the LED was kinda of hard to see with all he day light. It should blink red/green a bunch when you first turn on the bike. Their website has a Set up calculator you can use to program the unit. Either enter your sprocket gearing, the difference in speed compared to a GPS, or the difference in distance compared to a GPS. follow the steps and you should be all set. |
Originally Posted by BPWilson_F3
(Post 904544)
So I got the SpeedoDRD by 12oclock Labs and installed it on my 96 F3. http://i51.photobucket.com/albums/f3...n/DSC01213.jpg First take off what ever fairings are needed to reach the speed sensor, luckily mine runs along the outside of the frame and was easy to get to. http://i51.photobucket.com/albums/f3...son/Speedo.jpg Once you find the speed sensor connectors unplug them http://i51.photobucket.com/albums/f3...peedsensor.jpg Next plug in the unit http://i51.photobucket.com/albums/f3...n/DSC01218.jpg Once its plugged in, turn on the bike. I would suggest making it some what dark as the LED was kinda of hard to see with all he day light. It should blink red/green a bunch when you first turn on the bike. Their website has a Set up calculator you can use to program the unit. Either enter your sprocket gearing, the difference in speed compared to a GPS, or the difference in distance compared to a GPS. follow the steps and you should be all set. are you going to mount it to your frame? |
The new unit was plugged into the connectors inline, so you didn't remove anything, is that correct? Does this override the stock speed sensor? Looks like an easy fix. Any pictures of how you mounted it once connected?
1 Attachment(s)
Originally Posted by cranberryroo
(Post 905425)
Here is how i mounted it Attachment 57001 |
