how to: install a bi-xenon projector lens light
1st GENERATION KIT https://img197.imageshack.us/img197/...69front.th.jpg https://img36.imageshack.us/img36/54...170rear.th.jpg https://img29.imageshack.us/img29/54...rearend.th.jpg https://img219.imageshack.us/img219/...leftend.th.jpg https://img297.imageshack.us/img297/...ightend.th.jpg https://img29.imageshack.us/img29/15...175open.th.jpg https://img36.imageshack.us/img36/40...verview.th.jpg https://img36.imageshack.us/img36/85...ionfron.th.jpg https://img297.imageshack.us/img297/...ionrear.th.jpg - 2 lens, it's also lamp-base for D2S/R bulb, with bulbs, with neon "angel eyes" decoration - 2 ballasts (5th generation - ultra slim, digital) - 2 controllers with cables - installation screw good chinese factory quality - cables a little weak, but others items good. lens frame made of steel/aluminium or something durable and weighty alloy (in the next generation, exactly in 3rd, it made of plastic - more light, but more fragile) high beam controlled by shutter, so it'spossible to blink. after installation reflector only hold lens, as bracket, so it make possible to tune up the headlight. sinse reflector and case of headlight don't constructively change, it's possible to return original construction or common HID OPTIONAL: angle eyes color: white, yellow, red, green, blue, purple color temperature: 4300K, 5100K, 6000K, 8000K, 10000K light model: H4, 9004/9007, H1 & H7, 9005/9006 chinese factory (HID LIGHTING CO.,LTD /www.hidlighting.com.cn/) price to July 16, 2009 is 82,5$ for bi-xenon projector lens light kit with 1105 ballast ( H4 4300k white ) + shipping. |
INSTALLATION mount it according to user manual, nothing serious problem in process of installation. so... 1. take off front plastic with headlight, take off headlight 2. disassemble the headlight: put it to the box and heat it by drier for 15-20 minutes, sealing material get soft and it's possible to separate the parts https://img198.imageshack.us/img198/529/dscn3184.jpg https://img512.imageshack.us/img512/2521/dscn3187g.jpg 3. assemble the lens on reflector, washer for H4 lamp-base fix it all in right position. https://img168.imageshack.us/img168/3039/dscn3196.jpg https://img168.imageshack.us/img168/2007/dscn3195.jpg https://img196.imageshack.us/img196/9387/dscn3189i.jpg 4. assemble the headlight back: join the parts together and send it back to "oven" after 15-20 minutes when sealing get soft assemble parts together tightly with fixing catches i used sealing that stay in grooves after disassembling the headlight 5. install headlight back on plastic 6. install controller and ballast. i found good place under control panel on "spider" for ballast and on air duct for controller 7. positive pole i connect to wire that goes from ignition to fuse. ground very good press to screw that hold on "spider" by additional nut. angle eyes i don't connect yet. it's all, nothing connection needed, controller have connector for standart headlight connector 8. install front plastic and all that off back on moto. adjust headlight. |
WARNING! FAKE! https://img442.imageshack.us/img442/...445a5be.th.jpg https://img692.imageshack.us/img692/...47a7d54.th.jpg https://img14.imageshack.us/img14/47...47f2de4.th.jpg https://img15.imageshack.us/img15/31...bc819e6.th.jpg https://img40.imageshack.us/img40/12...5862d25.th.jpg https://img15.imageshack.us/img15/70...4a59241.th.jpg https://img694.imageshack.us/img694/...03c91ba.th.jpg https://img94.imageshack.us/img94/30...670fc61.th.jpg https://img15.imageshack.us/img15/28...781be93.th.jpg low quality bulb. low quality reflector, after using: https://img693.imageshack.us/img693/...7014907.th.jpg |
How long have you had it on your moto? That is bad a$$ky.
Originally Posted by drunkinmist
(Post 840306)
do you have any pictures of just the angel eye when it is on???
Originally Posted by pontyhufc
(Post 846512)
That is freaking awesome I should do that on my f4.. And black out the chrome backing. So this just bolts in, theres no hacking of the headlight ?
Originally Posted by xjoewhitex
(Post 862846)
btw, with this decision on F4i or RR (if it fit in) it's simple to make both headlights work normally HI/LO beam, and don't blind the other way by alway on hi beam. |
