How To: F4i Gauge in F3 Mount
I have been looking for a guide on how some people mounted their F4i Gauge in the F3. Here is what I did using the stock F3 Gauge cluster.
Remove the Gauge (7 Screws)
Using a Dremel tool, cut off the portion of the gauge that is raised so you have a nice level surface
Find out where you want to mount the gauge and trace the lines out on where the extra cuts need to be made to make it fit
Cut some cardboard to fill in the gaps. I just cut them tight enough to where I didnt have to use tape to hold them in, but Im sure that would work too. I also put a piece of plastic over the gauges just in case I dripped jelly on it
Cut fiberglass strips that are made to fit the areas where there is cardboard
I used Fiberglass Jelly. Im sure resin would work too, but this is a cleaner approach in my opinion
Apply Jelly-Fiberglass-Jelly In that order to the areas where you have the cardboard
I only used one strip to each section, you could use more if you like.
After it hardens, Sand down the rough spots of extra Jelly and then apply your Bondo. This takes a few coats as you can see here. After each coat. Allow to dry and then sand. I used 80-120-150-400-600. I also used 3 coats of bondo to get it where I was happy
Let this dry overnight, Then tape off your gauge and cut around the gauge to make a clean and even paint area
Primer 3 coats. i used Duplicolor Primer
Trim paint 3 coats. I used Duplicolor Automotive Trim paint
Clear 2 coats. I used Rustoleum for Plastic and Wheel clear
After you are finished allow to cure for 24 hours. Take the tape off and Enjoy.
Mine has minor imperfections and I still have to clean off around the gauge itself. You get the picture though.
Making the bracket will come next. I have not done that yet, but will very soon. Keep checking back for Updates.
solidsnake1761
05-08-2012 05:39 PM
Armstrong
06-08-2006 08:31 PM
