How To: F3 HID Install
#21
This is the Kit you would need for the F3 if ordered online right now
Single Hi/Low HID Kit
When you went into the store, what did you tell them you needed?
Also keep in mind I did this install 2 years ago, DDM might not carry the exact same kit I ordered and used for my write up. For instance they no longer carry the kit I bought and installed on a car I had a year ago.
#23
Yeah it was similar but not exactly the same. I managed to install it though. I couldn't get the DCU mounted up by the fuse box, it's ziptied along the frame near the engine (but not on it).
I had to ground it on a random part of the frame since it couldn't reach to the batter AND be able to hook up to the ballast.
This guide did help a lot though, thanks!
#24
hey,
So i did this mod quite a while ago. I also installed the 10 sec delay relay to keep the light from kicking on until after the bike is running..i dont know if its always been like this (havnt used the high beams much) bu when switching from the high beam to low beam, the light turns off completely and has to go through the 10 second wait before the low beam kicks back on..
Any ideas as to why its doing this? its kinda dangerous..lol. its either i cant see well because i dont put the high beam on, or i cant see at all when switching back from high beams..its gotta be something stupid..
#25
hey,
HB____
LB____>[HL switch]________[Fuse]________+[Batt.]
#27
So it only delays when switching back to low from high, and not from low to high?
Is there a necessary reason for the delay?
#30
its protects the bulb and ballast, gives it greater longevity due to less cycles. rather than on off on for a single start (which realistically, how many cold starts do f3's stay running the frist start..), its just....on
its not needed, but i added it because i wanted it and wanted the bulb and ballast to last as long as possible
