Flushing the antifreeze of a 600rr 2003
Hi everyone! In the coming days I'm gonna flush & replace the antifreeze system of my 600rr. I know it's a simple process but as it's the 1st time I'm doing it on my bike I appreciate any kind of instructions. To flush the water just by removing the hose pipe attached to the radiator, or there are any bolts on the water pump that have to be removed so that it will be drained fully?
1 Attachment(s)
Yeah, there's a couple of bolts you remove to drain it out of the block. Look in your Service Manual for the procedure. Otherwise you can just disconnect the hose going to the water pump, and make a big mess, lol.
Attachment 64143 |
Bolt on pump and bolt on cylinders. Should also replace the copper washers, they are compression seals like the oil drain plug washer.
Thx alot for all your help & info..... :)
Here is my detailed coolant flush, hope it helps should be the same for the RR
https://cbrforum.com/forum/showthrea...light=bluej511 |
