F4i Air ducts LED turn signals...
1 Attachment(s)
Hi everyone!!
Before anything I want to say that this is a "Reloaded" version of the How to did by Axsys. Check it here. So, lets make it... In a few words, if you have flushmounts in your F4i, its very difficult for everyone else to see you turn signal from the front of the bike, so like Axsys did but with more leds, I put exactly 20 superbright leds in each air duct. Parts Needed: -40 superbright Leds (a few more would be ok) -Red/Black wire -Solder Tools -8 Resistors, exactly for RED superbright LEDS, 180 ohms 1/4w -Glue Gun -Silicon sealant. Step 1. Take your front upper fairing off, disassemble the 2 air ducts grills that are attached to the fairing. At this point you have to choose which design to make, remember you have 20 leds to use. I put 10 leds one step before the top an the other 10 on the outter side of the grill. (You'll see them in the pics) Step 2. You have to make 4 series of 5 LEDs for each side, you have to solder the + to the - of the next led, at the end of the 5th led you have the negative leg and there you need to solder the resistor. Like this Attachment 11559 .....:icon_wink: |
5 Attachment(s)
:icon_urinal:....
Step 3. Once you have the 8 series of 5 leds (4 series each side) looks like this... Attachment 11564 Be carefull to NOT solder all series of leds equally, depending on the design you choose you gonna have to measure the space needed between each led. For my design i have to solder for 1 series 4 leds with no space between and the 5th led with a space of about 3mm. Attachment 11565 Now you have to paste each series in the air duct grill with the glue gun like this... Check the bottom led, that's the space i told you above... Attachment 11566 Cheers!!!:icon_shrug: Attachment 11567 with 2 series Attachment 11568 with 3 series Attachment 11569 :icon_urinal:..... |
5 Attachment(s)
Sorry the attachment didnt work, the 4 series looks like this
Attachment 11570 Step 4. Now that you have all leds series in the grills you have to start wiring all. You can join all positive + and all negative - wires like i did. Attachment 11571 Attachment 11572 Attachment 11573 Attachment 11574 |
5 Attachment(s)
Step 5.
Now that you have all wired up, you have to hide all wires and after that put some sealant above the wires to protect it from water. Check out theres no wire left without sealant, also check the connections that has been covered with enough sealant. Attachment 11575 Attachment 11576 Attachment 11577 Putting silicone sealant :icon_blah::icon_blah::icon_blah: Attachment 11578 Attachment 11579 :icon_hyper::icon_call:..... |
5 Attachment(s)
Attachment 11580
Attachment 11581 Attachment 11582 Now hold all wires with a zip tie to the bottom of the grill. Attachment 11583 Attachment 11584 Ok, so now you are almost done, you just have to connect the wires to the turn signals and YOU'RE DONE :icon_denk:. I know that i miss some steps :icon_doh: but you can ask if you feel a little confuse. ---:icon_teeth: |
4 Attachment(s)
The results....
Attachment 11585 and i also put on my headlight a Led strip, how does she looks?? :icon_pimp::icon_denk: Attachment 11586 Attachment 11587 Attachment 11588 I feel very happy with the results, in a few weeks i'll make the same for the passenger pegs, i'll post it when i do it... :icon_beerchug: |
Hey, nice howto think i'm going to try this. One question, where did you get you're leds from?
Originally Posted by exodus191
(Post 970630)
Sorry to bring up a oldish thread but do you have pics without the flash? I don't have front signals at all and I'm thinking about doing something like this.
i never thought of that. great work i am gonna have to try something like that on my bike
i'll post pics when i get around too it |
