DIY: F4I Headlight L.E.D DRL Mod
First off,
Hello everyone here is a quick Diy on how to install L.E.Ds in your headlights This Diy will be quick and to the point any questions/comments feel free to post them up. Also Feel Free to repost anywhere you want with credit to myself and CBRforum of course. http://farm5.static.flickr.com/4093/...a3f8cf6dc2.jpg Materials needed
1. remove headlight 2. remove headlight bulbs! Bulbs + Oven = http://www.smileydesign.net/smileys/act09.gif 3. preheat oven to 325 degrees 4. place headlight on baking sheet in the middle of the oven for about 2 to 2 1/2 minutes 5. remove headlight from oven and use a flathead screwdriver to open the clips while you pry the lense from the headlight housing. i found it easier if you start on the bottom of the headlight and work your way around. http://farm5.static.flickr.com/4079/...f56dddd2de.jpg take your utility knife and cut the glue as you pry. http://farm5.static.flickr.com/4139/...bd476cfc7a.jpg once you have enough room you can put your fingers inside and gently pry the headlight apart. http://farm5.static.flickr.com/4099/...f3f7c97e6e.jpg 6. set the housing aside and look at the back of the lense. there is three screws we need to remove. two on top and one in the center. http://farm5.static.flickr.com/4136/...25fab2e3aa.jpg 7. remove the fascia from the lense. it pulls out pretty easily 8. install your L.E.Ds. install them as close to the front of the lense as possible. for my install i chose to use L.E.Ds from autozone. one pack of white and one pack of amber. http://farm5.static.flickr.com/4100/...72a331e8_b.jpg http://farm5.static.flickr.com/4143/...83650b98_b.jpg the white L.E.Ds will be daytime running lights and the amber ones will be wired into my turn signals. http://farm5.static.flickr.com/4074/...9b2d1e63fd.jpg http://farm5.static.flickr.com/4073/...26d7c14f8d.jpg http://farm5.static.flickr.com/4139/...89af2bfa13.jpg http://farm5.static.flickr.com/4115/...142a3269fb.jpg 9. reinstall the fascia with the wires coming out 10. place the lense and housing back in the oven for 2 minutes on 325 11. pull the headlight out 11.A. (optional) insert your rubber butyl/glue/sealant into the groove on the headlight housing 12. quickly line up the lense with the groove on the headlight housing and push the two pieces together with as much force as you can without breaking anything. remember to pull the wires out. you can pull them out between the lense and housing without a problem to keep the wires out of the way you can tape the to the front of the lense ON THE OUTSIDE :icon_doh: 13. now you have three options... use wood clamps to hold the headlight together, place the headlight in a vice, or wrap the headlight in a towel and while keeping pressure on the headlight wrap run 3 strips of duct tape as tight as possible over the headlight. one strip over each headlight and one directly in the center will work. Get it as tight as possible! 14. allow time for your headlight sealant to harden. if you used extra sealant remember to read the package and find out how long it takes your sealant to harden. 15. install your headlights and wire up your L.E.Ds! Enjoy your new toy! :icon_playing: EDIT! hey guys just an update here.. my original l.e.d's are still looking and working great but i would like to add if you want more light to show for morning/noon riding i would definately go with a brighter LED than the ones advance/autozone are selling. but for evening and night riding they are beautiful and very easily visable. thanks again and i hope you guys like this easy mod |
Damn, i thought doing this thing myself, but you did it first lol. It looks pretty well, did you have any problems folding the upper corner of the leds strip in the headlight?? Anyway, it looks excellent.
How many leds has each strip?? |
thanks. it was no problem at all after you remove the inner fascia as i described. theres 18 in each 24" strip
Any after pics with the headlight installed back on the bike?
that's really bad ass dude and a great safety mod. i might have to do the same on my bike
have you thought about putting the led's in a diffuser to just get a nice even glow? I might try to do something like that actually instead
quick question. im wiring up my turn signals. and i cant get them to blink. obviously black is ground and red is hot. but on my side signals i have 3 wired. and the strips have two.
Originally Posted by itsme71190
(Post 985658)
i just conected to the hot. and wired it for when i hit a designated signal, the led strip on that side will cut out and the blinkers will blink. i like it.
