-   How-To: Mechanical (https://cbrforum.com/forum/how-mechanical-40/)
-   -   conversion from f3i front end to f4i (https://cbrforum.com/forum/how-mechanical-40/conversion-f3i-front-end-f4i-85799/)
cbr6exy 01-10-2009 11:53 PM
Does anybody know how hard it is to convert the f3 to f4 front and wat all is needed?
MrBomb 01-11-2009 01:41 AM
RE: conversion from f3i front end to f4i
yeah its been talked about a few times here, just do a little searching
it does look awesome when done, good luck if you do try it
rellimdekim 01-11-2009 01:49 AM
I am not quite sure about this. I mean The F3is are a really rare bike to begin with... F4i`s are a dime a dozen so the front end should be easy to find, but be careful not to break the hardware on you`re F3i, I hear they are impossible to find.
For clarification from everything I read the f4i front end will work on the f3 as long as you transfer the whole thing. Meaning you mount the f4i`s triple tree onto the f3`s frame. I wont attest to this because I don`t know for a fact, but it makes sense as the down tubes on most hondas are the same size.
axsys 01-11-2009 04:41 PM
ORIGINAL: rellimdekim
the hardware on the f3i is identical to the f3, just that it is all made out of solid gold instead of aluminum/steel ;)
rellimdekim 01-11-2009 04:46 PM
that great news for 6exy...
...you hear that man you can use the regular f3 hardware if you strip a bolt!
