Chain Maintenance- **VIDEO**
Guest
Posts: n/a
Really depends on the conditions it is used in and the type of lube used ...
If you are in a dusty area and the lube you use tends to attract the chit from around it ....then maybe every 6 mths is a good idea...
but if you only ride on good roads with little dust around , prolly once a year is plenty... but as I said it is a case of what lube you use and where you use your bike usually ...
Just take a close look at your chain every now and then and if you can see a visible build up of chit on the outside of it ...then hey , if you are inclined , clean it
