brake job fiasco
brake job fiasco
After some difficulty with the piston caps sliding off during the operation, I recently replaced front pads on my 87 Hurricane. They seem a bit snug but the wheel seems to turn OK. The brake light however is stuck on now, even though I have completely adjusted the adjuster for it. The brake lever does not go back as far as it used to. Also, I am now dripping brake fluid slowly on the right. Though I better post this b4 doing the whole job over again. Thank you for any response.
RE: brake job fiasco
Sounds like you've lost pressure.
Sometimes you can over pressurize with the c-clamp and if the resovior cap is on it can cause that pressure to find it's way out of the system.
I would check and replace the crush washers and inspect the banjo bolts. Where is the leak coming from?
Hayden06F4i
06-17-2008 09:50 AM
