Yeh bacdog knows his Hondas, and heres another one to look at ,this guy actually put both springs back in:)
Honda CBR 929rr/954rr: HOW TO: CBR 929 Factory Pro Shift Kit Install w/ Clutch and Tranny Assessment |
Originally Posted by Rusty43
(Post 1319318)
Pic #9 shows spring tail at 11 o’clock position. That’s 180* more rotation than what I used. I’m installing factory pro shift kit with their heavier spring, and it will be a Royal pain to put that much tension on the shift lever. Does the lever require that much pressure? I’ve seen other photos with the spring tail at 5 o’clock on the shift drum retainer bolt boss. Very good user install write up |
Detent spring
Thank you.
[QUOTE=backdoc;1277319]UPDATE: Since replacing the drum and shift forks a few months ago I have not experienced any missed shifts or the bike falling out of gear. I am also using an air shifter now at the drag strip with great results to ensure no lazy shifts from me. For anyone who is experiencing shifting problems with their 929/954 I would recommend changing these parts before removing the engine and splitting the cases to replace gears in the transmission.
So Backdoc I just wanted to clarify and see if my issues are the same as yours..long story short I was riding down the highway one day and heard a pop and was told that it was my clutch fork so now I can’t get my bike to go into 3rd at all, would me purchasing these parts allow me to fix that issue? Because this far it has been said to me that I just need to purchase a whole new motorcycle engine. |
