WTH hav i done lol
WTH hav i done lol
Hello I'm new to cbr form thanks for the invite....I hav what I hope is not a major problem,I jus bought a 94 cbr 600f2 everything has been runing and workn great untilled today. Well yesterday I decided to remove my signal lights and install them in my tail light first I removed the signal lights,then I cut the undertail out and installed new led bulbs in the tail light, after everything was put back together I turned the key on to check and see if it worked well the left signal blinks faster than the right so I changed the leds to regular bulbs and still had same problem I also noticed that now when the high beams are cut on that the blue indercater light doesn't come on anymore so I took the key out and left everything as is well today when I went to start my bike it wouldn't start so I jumped battery and checked voltage while it was running and it only had 11.4 volts so I removed battery and took to parts store to get checked,the Guy said it only had 9 volts and he recommended leaving the battery over night to trickle charge sense it was only 3mts old.so my question is, is there anyway I coulda hookd up something wrong that caused all these problems, the only wires I cut were to signal lights, and sense all this happened I unhooked the signal lights and license plate light and capped off wires...the head light and tail light still work...I also bought a new intergrated tail to install, thanks for takn time to read my post and help w/problem....any help is greatly appreciated thanks
BTW, typically, when you change from bulbs to LEDs, you'll get that high blink rate. To slow it down, you need to add a flasher-relay to slow it down. Personally, I like the faster blink rate. So, I left mine alone after installing LEDs.
Good luck.
