-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   wiring sat nav (https://cbrforum.com/forum/general-tech-9/wiring-sat-nav-164866/)
hellrizer2029A Feb 12, 2025 01:18 PM
wiring sat nav
Evening all I have a questions with regarding a sat nav ( TomTom rider 550 ) and where to place the wiring for it as i don't know where to place it in the bikes wiring loom or directly to the battery on a 95 CBR 1000F
rockpool Feb 12, 2025 03:10 PM
I ran my accessory positive feed from the post on the starter solenoid/fuse - it was neater than having a bunch of wires around the battery. The ground can go anywhere on the frame - it does not have to end up near the battery.
hellrizer2029A Feb 14, 2025 12:35 PM
starter solenoid/fuse is that the starter relay and if so when ignition is turned off does the sat nav not charge or does it still charge. and you don't by any chance of a picture of the starter solenoid.
hamlin6 Feb 14, 2025 05:57 PM
If you look at an online parts reseller, they will have an illustrated parts breakdown for your particular bike. That should get you what you need.
hellrizer2029A Feb 15, 2025 04:19 PM
i did look online and there was about 3 different images 1 for the 600F and 1 for the 1000F and a plug style relay and i also looked at the wiring harness image and it wasn't there so i had to look in the Haynes manual and found it
