windscreen
Hi i have a 2000 f4 and just got a double buble windscreen is it hard to change i see the top few bolts you can get easy what about the other ones.??
RE: windscreen
not sure on the F4 but the RR you just take the plastic screws out and the window out. Just be carefull the screws strip easy!
RE: windscreen
Yes, it's easy.. You'll probably laugh at yourself for asking. It took me 5 mins tops (3 of them were spent shining it up after it was installed)..
Just unscrew, and pull off. Reverse to install. |
RE: windscreen
hmmm sounds complicated, I better get out the tig welder just in case:D
RE: windscreen
you sure you dont want mig, it is in the window area after all [sm=drooldude.gif]
