When can I expect to replace brakes and clutch? (14k miles now)
RE: When can I expect to replace brakes and clutch? (14k miles now)
brakes...about now...but check your wear indicators. if you're hard on them then you'll need to change them.
i need to change my brakes about every 12K or so...i'm hard on them...to semi hard on them.
as far as clutch...you're ok at 12K...i'm at 38K and mines still working good mang.
replace when it's slipping. otherwise, just change your oil and such and you're ok. you should probably change your plugs if you haven't though...and suspension fluid, and bleed your fluids...like brakes and coolant.
