What are they called
So I am in the process of pulling the carbs off of my 92 CBR 600f2. There are 4 rubber gaskets when you take the air cleaner box off. I cannot figure out what they are called. I am trying to find out so I can order just those and not the gasket kit A. Any Help would be nice. If this has been posted before I am sorry. I did a search and found nothing on the subject. Any help would be great.
No that's not it. It is the rounded gasket that I think is in the gasket A set here https://www.partzilla.com/catalog/ho...tor-components but for some reason they don't have it listed in the schematic and I don't know what it is called to be certain. Thanks for the try though.
Those seals are most likely only available in the set. It would not be a bad idea to get the set, (you may need 4 if the set is 1 for each carb) because eventually you will need the other seals to do work on the carbs.
The other options are to leave them out as its not metered air there,its or make your own. Best way to deal it is to put a thin smear of silicone on the air box side and let it completely dry. When you bolt it up, it will be soft enough to seal without sticking to the carb.
