-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   What temp does cooling fans come on? (https://cbrforum.com/forum/general-tech-9/what-temp-does-cooling-fans-come-115099/)
Sean80 Aug 11, 2010 07:22 PM
2004 600RR... temp hits 212....no cooling fan... run at 170 while riding though no problem.. might just not have given it time to kick on? dunno figured id ask
*EDIT* nevermind. its set to 220 F from the factory lol. --shrug-- guess its just normal for your balls to be hot.
ridefast Aug 12, 2010 08:13 AM
i have a 2002 f4i and my fans don't kick on until temps hit right around 226 or so.
Sean80 Aug 12, 2010 08:32 AM
yeah they kicked on when i rode it this mornin when i was at the gas station. were good lol.
off subject but... im not used to the engine wanting to just run at high rpm... even in 6th gear at 65-70 mph its at 3-4 k rpm... dunno if the previous owner put a diff sprocket or if its normal.
RoadiJeff Aug 12, 2010 11:27 AM
The Gearing Commander website will tell you what the rpm should be at a specific speed and gear. Also will tell you what the stock size sprockets are so you can compare with what you have.
drunkinmist Aug 13, 2010 12:16 PM
Most fans will kick on at 220-225 all depends on the thermostat that is installed. I cant say for all honda's but at least for the f4i's they come on at 225.
meccaonez Aug 17, 2010 02:14 PM
Yeah it was 220 on my CBR 600rr and 225ish in the 954 RR
