What does peak voltage tells? - CBR Forum - Enthusiast forums for Honda CBR Owners
Thread Tools Search this Thread
Old 02-09-2018, 09:39 AM
Question What does peak voltage tell?
i have a question regarding the peak voltage testing which i haven't done so far
normally i use resistance as the measurement to check my stator, ignition coils and pulse generator in my Fireblade. it clearly shows the coil resistance as well as the coil short circuit or open circuit. once i had a bad pulse generator which went open circuit randomly. so with the multimeter i could diagnose that error and replaced it with a good one so the resistance reading helped in that situation.
but in my manual it advises us to perform a peak voltage test apart from that resistance test. it applies for both the ignition coil primary side and the pickup coil. it says reading should be 100V or above for the ignition coil primary side and 0.9V or obove for the pickup coil. it seems that we have to have a special adapter for our multimeter to perform these two tests. i googled and found some information but didn't find a good explanation.
so my questions are,
1) what does the peak voltage reading tell us about the ignition coil primary side and the pickup coil? now i'm aware of performing these two tests but i'm not clear what that reading tells. specially in that ignition coil primary side test.
2) to rule out any problem do i need to perform both the resistance and the peak voltage tests? isn't the resistance test enough?
thank you.
Old 02-10-2018, 03:24 AM
This should show the reasoning behind using the PVA ,easier to do it this way as I'm a one finger typist
Also here's one I made earlier
https://cbrforum.com/forum/general-t...daptor-156906/
What does peak voltage tells?-pva.jpg1.jpg   What does peak voltage tells?-pva.jpg-2.jpg
Old 02-10-2018, 08:45 PM
thank you very much.i'll read it
Old Today, 04:36 AM
hello. i have an update here first of all big thank to CaBaRet for his DIY peak voltage adapter and the continuous support
i made a peak voltage adapter with the help of him and it worked really well. i could measured both my pulse generator peak and the ignition primary circuit peak. in my circuit i used 2.2uF 450V capacitor since i couldn't find a 1uF capacitor.
here's a useful link if you are going to make one yourself also you can check CaBaRet's DIY adapter post thank you.
Thread Thread Starter Forum Replies Last Post
Peak Voltage Adaptor CaBaRet General Tech 2 12-12-2017 08:05 AM
Pikes Peak... our Isle of Man? Conrice Sights 'N Sounds 2 09-01-2012 11:25 PM
6 Things no one tells you about a motorcycle CBRfenatic93 Off Topic 11 05-28-2011 05:34 AM
Sneak peak g32bturbo F2 Media 6 09-30-2010 05:37 PM
Gemineye from Def Poetry tells it like it is Mad Sights 'N Sounds 1 08-07-2007 08:08 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Featured Sponsors
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
