Wet Plug help
Old May 12, 2010 | 04:16 PM
sean_k's Avatar
Default Wet Plug help
I have a 94 F2 that has been running a little rough lately, nothing to bad though, seems to be better at higher rpms So I decided to pull the spark plugs to see if maybe they were bad, only a couple of months old, and the number three plug was wet. I know that is not a good sign but what does that really mean? is it a bad gasket or something along those lines?
Old May 12, 2010 | 04:50 PM
pacemaker's Avatar
What did the other plugs look like? Nice tan colour usually means their working ok
Wet plugs usually means that its not burning off the fuel, if you mean an oily looking plug, then maybe worn rings. One plug though? could be carbs/Spark plug lead/coil.
Old May 12, 2010 | 05:05 PM
HenryM's Avatar
Do a spark test to make sure the plug working. If it's not take out the other plug that shares the coil and see if that working OK. If it is then you've probably got a duff plug. If changing it doesn't help then you may have a bad HT lead.
Keep working back logically down the line and you'll find the culpret sure enough.
If the plug is sparking OK and is still wet then you may have a flooded carb or that pot is running very rich for some reason.
Is there any visible smoke from the exhaust when she's warmed up and ticking over?
Old May 12, 2010 | 05:52 PM
sean_k's Avatar
thank you guys I will work on that and see what happens.
pipedcbr
Dec 29, 2010 12:25 PM
Coopz
May 23, 2008 06:36 PM
Shadow
Apr 9, 2008 02:20 PM
grim129
Jul 30, 2007 08:48 PM
allnath3
Nov 5, 2006 12:31 PM
