weird clutch problem
Old Sep 5, 2006 | 08:18 AM
thekid_600rr's Avatar
Default weird clutch problem
I have a 05rr and well around 8-9thousand miles the clutch started well it was sliping at high rpm's, i would have to let off and let it grab and then take off again. well a wile after that the tension on the clutch was real tight so i would lossen it and it would get tighter a few hundred miles down the road. then i would lossen it. I allways thought that when your clutch goes bad it would get loser. I dont know. Any help would be great. I have a barnet clutch now still waiting to put it on but i would like to prevent any problems witht the new clutch.. thanks THEKID
Old Sep 16, 2006 | 02:28 PM
gixxereater's Avatar
Default RE: weird clutch problem
Sure sounds like a burnt clutch. Probably warped steels or burnt. Put the barnett in and adjust correctly and you shouldnt have any problems.
Old Sep 16, 2006 | 04:39 PM
chaos321's Avatar
Also when you take it apart, use a scotch bright pad to clean your steels so that you get the glaze off of them.
asides
Apr 29, 2010 06:32 PM
Ratt
Dec 2, 2009 03:13 PM
Mr.S7
Jun 4, 2009 01:34 AM
Jettfiery
Aug 27, 2008 01:02 PM
motorcyclemechanic
Mar 10, 2006 01:50 AM
