Water pump question
Old Feb 8, 2009 | 11:31 AM
cbrf4bp's Avatar
Default Water pump question
I'm in Michigan so obviously not much riding gets done this time of year. I went out to the garage and uncovered and moved my bike so I could get to something in the back. Underneath the bike was a puddle of coolant about the size of a 50 cent piece so I pulled the fairing and found the water pump to be dripping the coolant. My question is does the whole water pump need to be replaced or just the seals? Thanks in advance for any advice.
Old Feb 8, 2009 | 01:24 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Just because you have a little leak doesn't mean you have to replace the pump. Figure out where exactly it's coming from and go from there. Could be something as simple as a loose hose clamp.
Old Feb 8, 2009 | 02:17 PM
cbrf4bp's Avatar
I already checked it out and it's coming out the water pump between the body and the cover. There isn't any on the hoses which is why I believe it's the water pump.
Old Feb 8, 2009 | 04:55 PM
Incognito's Avatar
Next step would be to re-torque all the bolts; drain plug included. If that doesn't do it then you probably just have a deteriorated gasket, imo. If the bike doesn't overheat, then it's not your pump, it's just a bad seal. Cheap & easy fix.
Old Apr 27, 2009 | 10:22 AM
bigdognicroc's Avatar
I'm having this same problem on my 929 did u get it fixed, I replaced the oring and its still leaking should I use some kind of sealer any one know?? B4 I buy a new waterpump thanx
exciter900rr
Aug 27, 2012 02:48 AM
jacksla3
Oct 5, 2011 06:58 AM
berga
Jan 16, 2010 04:41 PM
teknoanimal
Aug 4, 2009 01:08 AM
zrad
Feb 27, 2007 11:58 AM
