Turn signal?
What bike is it?
Totally incompatible connectors, so which is OEM?
Where did you get them non-OEM part? what model number? What type? Etc!
We're happy to help but you have to help us to help you.
I'm sorry for the lack of information. It's a 2006 F4i and the guy I bought it off took off the front turn signals. I still can't understand why. Got these replacements off eBay that I will never do again. I just have to solder them together but can't find much info. It was soft packaged and had to epoxy A piece back togther so I'm in a bad mood. Happy to be back on a CBR. It's been 15 years
NO!!! DO NOT HACK UP HARNESS!! you’ll end up witb shorts and blowing fuses forever. Get factory OEM connectors and put them on aftermarket lights. You’ll need 2-wire Sumitomo connector and 1-wire ground.
Follow my guide here:
https://www.600rr.net/threads/diy-co...arness.587929/
If these are LED lights, you’ll also need to install ballast resistors. Then install is simple plug-n-play. Like this.
I like Partzilla.com
Ebay’s also good source for used/NOS parts for older bikes.
baboon.eu is surprisingly good deal sometimes. Recently got fuel-pump assembly for my SFV650. Even with international shipping, it was less than what local breaker yards were charging.
Rempt
May 30, 2023 03:59 PM
