Trun singnals
RE: Trun singnals
You will need a minimum of two. They go across the + and -. One side of the resistor ties to the + the other side of the resistor ties to -. I would try two and see what happens if the just turn on and don't flash then you need to add the another pair to either the front or the back (which ever end you didn't tie the first set of resistors)
RE: Trun singnals
i've got led's front and back, have 2 resistors on the back but everything still blinks fast when i added the front led's. i've been told that you can buy a non-load sensing flasher to replace the factory one, haven't done it yet but that's the route i'm gonna try. the resistors get hotter than i am comfortable with.
