trouble syncing carbs
Old May 29, 2010 | 09:52 AM
Michaud85's Avatar
Question trouble syncing carbs
I tried syncing my carbs last Night at normal operating temp but I simply could not get all of them to equal eachother I can easily sync one carb to another and sometimes I can get 3 synced but I can't get all four of them equal.
Does anyone have any advice or is it just guess and test till they are equal
It keeps taking me so long to do it so I have to shut the bike off and let it cool down
Old May 29, 2010 | 10:30 AM
When synching your carbs, you do it in pairs. You work on carb 1 and 2, turning the screw between them getting them balanced. Then adjust the screw between 3 and 4 getting those 2 balanced to each other. Then you adjust the screw between carbs 2 and 3, which brings the left side (1 and 2) into balance with the right side (3 and 4).
Old May 29, 2010 | 03:06 PM
justasquid's Avatar
One thing to consider is placing a box fan in front of the bike while your doing the carbs. You should have airflow going through the radiator so you don't have the heat issues. It will simulate you coasting about 10mph, and the bike should stay cool. the fan may kick on, but at least with the box fan, it can cool the bike back off and keep it in the right temperature range.
DId you get the bike to not flood?
Old May 29, 2010 | 03:56 PM
Michaud85's Avatar
thanks squid and dirt i finally got them sync'd
Old May 29, 2010 | 09:04 PM
It's all good...
Old Jun 29, 2010 | 01:35 AM
antatious's Avatar
I just thought I would bump this. I looked for a little while for this exact information. I finally got it here. I am definitely new to carb synccing. I had no idea how to do 2 at a time and in what order.
Thankyou.
Old Jul 3, 2010 | 11:01 AM
You need to get a Carb synchronizing tool like the one here. All 4 carbs are hooked up. You adjust 1 and 2 to each other so they're balanced, then 3 and 4 to each other, then balance the left and right side to each other. This was taken several years ago, but shows the effect you're looking for.
http://www.youtube.com/watch?v=Hmw-1XYS3UY
littledjt
F2 Tech
Jul 19, 2012 08:25 PM
TechGirl1414
Oct 14, 2011 08:45 PM
malbojah
Apr 1, 2008 07:48 AM
dahokmog23
Oct 8, 2007 09:31 AM
nrok2118
Apr 13, 2007 08:17 PM
