Tire Pressure Question
I got a new front tire, brand new installed by New England Cycle Center here in Connecticut. They filled the front tire up to 42psi - I have a 2000 CBR600F4, in my PDF Manual it states the front should be at 36psi and rear should be at 42psi. Question I have is, do I set the front to what they have or put it to the manual specs of 36psi?
I have a 99' F4, with PP tires front and back, and for normal everyday riding I use 'almost' bike/manual spec pressure. 38 Front, and 40 Rear... but I always wondered why the front was supposed to be lower than the rear, because in cars you want the front to have higher PSI than the rear....which is why i run a little higher in front, and lower in rear than the manual suggests, but still close... I was thinking about experimenting with different pressures soon, but for now thats how i normally run it...
If the manual states to have 38 psi., then that's what you ought to have in it, not above it. Also, on the sidewall of the tire there is a "max pressure" label which will indicate the maximum air pressure allowed for that particular tire, typically as "cold" psi. Cold means that the tire must not have been riden and allowed to warm up.
Some people like to run their tires under pressured, but you should never run them above the maximum limit indicated on the sidewall.
