Throttle Position Sensor suspect? CB 600
Old Aug 4, 2022 | 11:13 AM
Yea I'll say, 20km/L is 47 mpg. That's nothing to sneeze at.
Old Aug 4, 2022 | 11:17 AM
dannoxyz's Avatar
Originally Posted by Bizzel
Hey @dannoxyz . I fitted the jets and it worked like a charm. The first tank it seemed I got over 20km/L, which is really nice. I'll look at the plugs in a few hundred KM's to make sure it's not running lean, but otherwise, everything seems right.
Thanks again for the help
You're welcome!
Good job! :thumbsup:
Old May 3, 2024 | 08:56 AM
bellerose's Avatar
Registered just for this since Im deep diving for another problem on my cb600f (2006). The TPS actually controls a fuel cut off valve (solenoid). Contrary to the name, it just cuts off air to the carbs on certain conditions. Its located under the fuel tank on the right side. Connected to the main electrical (you can plug it off to test out if it's causing you problems). Might also connect to the coils, but I don't think so after looking at the electrical diagram. You should definetely find the service manual for your bike, lmk if you need it, I think both models use the same (mine has pre 04 and after 04 sections for most things).
Also the main jets have tiny numbers on them, should be #108 on the outside #110 on the inside carbs.
dgk600f4i
Sep 19, 2013 04:22 PM
lishfireman
Aug 17, 2012 08:46 AM
steevoz
Sep 22, 2009 09:54 AM
PapaPepperronio1
Apr 10, 2009 08:52 PM
oneshotuno
Aug 31, 2008 07:13 PM
