-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Throttle cable help on a 1996 cbr600 (https://cbrforum.com/forum/general-tech-9/throttle-cable-help-1996-cbr600-116616/)
daddywilson Sep 16, 2010 10:27 PM
I recently got a 1996 cbr600 and the carbs had already been taken off due to sitting for along time and they were gummed up with dead gas. so the people who took off the carbs cut the throttle cables to get them off so i never got to see how they were routed. i got new cables but cant seem to keep the pull cable on the pully it keeps popping off when you pull the throttle back. is their any diagrams for putting on the cables and any advise from from anyone who has done this before? thanks in advance for any help.
IDoDirt Sep 16, 2010 11:04 PM
1 Attachment(s)
Unfortunately, I don't have any photo's of them. This is probably the best diagram of where they go. As for installing, If you're having to install from scratch, then attach them at the carbs first, then attach them to the throttle grip while the grip is off of the Clip-On. After you have the cables wrapped around the throttle, it's then pretty easy to slide the Clip-On into the throttle handle. Naturally you would be doing this with the Clip-on off of the fork tubes.
Attachment 53505
