take off front wheel
check out www.stephygee.com for manual...and download it.
basically, get bike on rear stand...get bike on front stand...
remove 2 brake caliper bolts on each side. remove caliper...do not press on the brake lever...zip tie them or something so they don't dangle.
loosen the axle nut bolt. loosen the pinch bolts at the bottom of the fork (2 on each side). remove axle nut, remove axle bolt...remove tire...
take to the shop for new tire, bring your own lube, tell them to be gentle, because you may be a$$ raped for the tire mounting and balancing...HAHAHHAHAHHHA
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
japanese900rr
Aug 15, 2006 11:52 PM
