Tail Light Wiring Harness
Approximately where was it on the bike?
It should be just as long as your replacement harness. There may be tape or a cover covering it which may make it difficult to feel for. But it shouldn't be longer than the new one you got.
I'm not so sure your replacement harness is for a 2000 F4. What I can tell you are the wiring groupings & wiring color codes for what should be back there...
For the RIGHT & LEFT Tail Light (two 3-wire plugs - one for each side) Each 3-wire plug has a solid green, green w/ yellow stripe, & black w/ brown stripe.
For the Plate Light (2-wire) - solid green & solid brown.
For Right Signal Light (2-wire) - solid green & solid orange.
For Left Signal Light (2-wire) - solid green & solid blue.
You don't really need any of those factory plastic plugs, especially if you are going to do an aftermarket tail light & signal setup.
All my wires are soldered and heat shrinked
