stator or rectifier?
Old Sep 14, 2007 | 03:26 PM
TripsD's Avatar
Default stator or rectifier?
I'll get straight to it. 93 F2. Just put a new battery fully charged in 2 weeks ago. Now the battery is getting drained and pretty much sucks. I had a fried wire in going into the regulator/rectifier and fixed that. I can still charge the battery to full and start up the bike but it gets drained out over a week or so of riding. 11.8 volts from battery not running, 12.8 running. getting 6volts from rectifier/regulator while running. Haven't had a chance to test out the stator. Anyone have a clue what this could be? i have nothing extra running on my bike. LED's are on a switch and are off 95% of the time anyways. I don't want to get a new stator when its the rectifier or vice vesa.
Old Sep 14, 2007 | 05:06 PM
TripsD's Avatar
Default RE: stator or rectifier?
Add--- The regulator is pushing out appx. 6v. not sure if thats low or not.
Old Sep 15, 2007 | 09:13 AM
redzintimidator's Avatar
theres a charging system flow chart floating around here from the other cbr forum....let me see if i can dig it up....it will tell you what to replace..worked for me great. most likely it is the regulator, dont know why but those like to blow..i got a new one and she charges like a champ!
anyways let me see if i can dig it up.
Old Sep 15, 2007 | 09:15 AM
allrighty...well that was easy..here ya go!
http://cbrworld.net/forums/thread/140473.aspx
Old Sep 15, 2007 | 09:16 AM
and i hope you know how to use a multi-meter..if not...LEARN!!!
Old Sep 15, 2007 | 03:11 PM
TripsD's Avatar
Thanks. I'll get on that this weekend and hopefully fix it. I know how to use a multi-meter. You put the red end on the battery and connect the black end on your nose. just kidding. Thanks again, hopefully it all works out.
Old Sep 15, 2007 | 06:27 PM
Drowner's Avatar
I would say its most likely the R/R. I had the exact same symptoms as you, i bought a GSXR one from amazon for about 30 bucks, wired it up, and the problems went away.
Old Sep 15, 2007 | 06:28 PM
Drowner's Avatar
BTW, if you are on the stock R/R, you should replace it anyway, its a known problem, expecially on the older bikes.
Old Sep 15, 2007 | 08:43 PM
TripsD's Avatar
is a GSXR one better to use than a OEM or aftermarket?
Old Sep 15, 2007 | 11:38 PM
Drowner's Avatar
well, the gsxr has the exact same wiring, and its 3 times the size, so the heat disipation is much better
