Stator???
Stator???
Just picked up a 95 CBR 600 today. It has a charging problem and I figured some of you guys would know better then anybody. I read through the " how to diagnose your charging system" thread, butit did'nt go past step 4. The battery wont hold a charge more then a few days. I can re-charge it and in the next day or two it will be dead again! Is that for surethe stator or possibly something else?
Thanks in advance for the help!
RE: Stator???
id check into your Regulator/rectifier. its located on your right hand side under neath the tail side pannel. that can cause the symptoms you describe. if you were to jump the battery and once you took the cables off the bike dies i would say that would be your stator. just go down to a local recycle yard and pick up a used R/R and then charge your battery or better yet go buy a new one. and chances are your problem will be fixed.
RE: Stator???
charge the battery and get it load tested, or just buy a new one and then do the electrical tests. The diagnostics relies on a good battery to test the output of the stator and proper operation of the regulator. If your battery isnt up to par, you will get conflicting results in your testing.
RE: Stator???
This is what I did today; took the bike out and drove it around until it shut off (prolly is'nt the best idea). When it did die, I took the battery to Autozone to test it. It read 11.53 volts. My lights would still turn on but the bike would'nt even start to crank. They charged it up to 12.30 and then the bike cranked right up! So what does that sound like???
