Stator?
Stator?
hey im back with that same ol 98 f3 i have completely eliminated a fuel issue with the bike its all top notch now . .when i bought it the guy said he was riding it and it started bucking and jerking on him out of no where (on the interstate) he was able to limp it home and later sucker me into buying it i was just wondering if its possible that the stator be the cause of this issue? its fine revving in the barn it will idle all day long but you put a load on that thing and it gets pissy . .any ideas? im thinking stator and or ignition pulse generator . . the bike has 20K BTW . .any help would be greatly apreciated
Have you checked for vacuum leaks anywhere? Mainly I would look around the carb boot mounts. You can start the bike up and spray some starting fluid around the carb base and see if the engine revs. You can also check around any sealing surface of the engine. Just use very light and quick spurts of it. You don't want to lay it on there thick, or you just might end up "lighting this on fire"
Have you checked your voltage at a high rpm? In very rare situations, the stator can be strong enough to run the bike and charge the battery, but be too weak to keep up with the demand of high rpm running. But, it is an rpm related thing, not a load thing. it wouldn't show up from just a load on it. Its probably not the issue, but I would still check it to see how the voltage reacts to higher rpms.
It could be the pulse generator. But usually it will just be a no start condition. But there is the possibility it is failing at load. Check the resistance on it to make sure its within spec. if its out of range, change it.
Can you re describe exactly what its doing? Does the rpm fluxuate? or does the bike just surge really bad? Can you ride it easy and have it ride normally?
it surges terribly . . . .if i smack into it i mean WTFO i can ride thru it it wont surge but it will kind of hesitate then go but by then im doin 90 so i gotta back off . .if i try riding easy ittl surge and buck and jerk and sometimes just bog down, i can really only ride at like 30 mph in higher rpms, the bike starts right up no issues i turn the choke on and hit the button and its pretty much instant when it starts turnin over no prolonged cranking or anything
also i just bought the bike back in march or so havent messed weith it to much so i havent had a chance to ride it anywhere and do further diag . . .i would if i had an M on my license but i dont and i dont need a bike breaking down on me and where im at the cops are terrible so thats the lat thing ineed is to be broken down without a license in a sense . . . .lmao that cop would have to break out a whole new ticket book for my a$$
From your description, it sounds throttle position sensitive. Which means you either have a lean condition or rich condition lower in the rpm range.
I know the previous owner said it just started to happen while he was riding it. But you can only trust someone selling something so much. Its very possible he messed with it and didn't want to admit he screwed something up.
I would still check for the air leaks creating a lean condition. Beyond that, you'll have to tear into the carbs again and see why its running poor in the low throttle input. Since it clears up some when your on the throttle, the main jet has taken over and compensation for the lack of fuel of what sounds like a lean condition. Inspect the pilot jets for proper adjustment and make sure they are clean. Also if your bike is equiped with the carbs that have the rubber diaphram in the top, make sure they are seated properly and not torn. If anyone had the carbs apart, the diaphram can easily become distorted when putting it back together.
