starting problems
i have had my cbr f4i since may...this is my first sportbike/4 cylinder. Any time I let the bike sit for more than 3-5 days it wont start off of the battery. I have to jump it and it takes over ten minutes to finally get it to kick. any suggestions, I keep it garaged i know it is not the cold weather.
[ul][*] How old is the battery?[*] Have you checked to make sure both the regulator rectifier and the stator are working properly?[*] What is the static voltage on your battery after a full charge?
[/ul]
[/ul]
I agree, also. Motorcycle batteries are notoriously short lived. If a new battery doesn't correct problem then maybe you have a VFR type issue where the bike pulls current while off. Try a Yusa and let us know.
ORIGINAL: Baldman
The 'shotgun approach' is an expensive option. If you check the things I mentioned, you could save yourself $90 possibly...or spend that $90 on the known fix.
I agree with your statement. And as it turns out, the problem isn't really what was described initially. [sm=smiley24.gif]
ORIGINAL: jamesb33
thanks for replying...it is not a battery problem the power is there and the starter is turning but the engine only sputters for a sec then cuts off. sorry for the confusion
[/ul]
