Spongy Brakes
Old 02-14-2008, 10:43 PM
SurfnSCal's Avatar
Default RE: Spongy Brakes
Specr you might have a slightly warped rotor? have a way to jack up front end and spin wheel?
Old 02-15-2008, 10:16 AM
SpecR's Avatar
I'm only going by prices you can normally expect to pay.
Also, the water isn't warped, since I'm talking about how the lever acts while standing still.
Old 02-17-2008, 10:24 PM
Thanks for posting this tip. I hadn't heard of it before, sounds pretty good. I replaced the old brake lines on my FZR a few months back with new Spiegler SS/Teflon lines, put in Motul RF600 DOT4 fluid and new HH+ pads. Did this for both front and rear. HUGE difference.
Definitely worth all the work, but remember, if you're going to do this, be sure to take your calipers apart all the way and clean them up really good and also get all the gunk off the pistons with "000" steel wool. Make sure you get new seals also, they're usually not cheap but if you're going to do it, and spend all the money on SS lines and HH+ pads, spend the money and time to do it right.
The outside of my calipers might be slightly dirty, but the insides look brand new. [sm=signs007.gif]
Old 02-18-2008, 08:17 PM
Jaybird180's Avatar
Surfn- Be aware that race pads need heat to work properly. Street speeds usually don't provide the heat range. They also tend to wear rotors faster. But thanks for the tip. I never before considered or heard of piston seal flex.
Brookhouse16
08-25-2014 02:14 PM
mikeyg2487
08-18-2014 10:14 PM
Nytmr
12-21-2013 09:16 PM
bboi
06-20-2007 06:56 AM
Quick Reply: Spongy Brakes
