Smell of Gas
RE: Smell of Gas
i would not classify this as a problem. all bikes smell like gas. we all have a gas vent tube that expels excess gas in the tank or gas vapor from pressure built up due to heat+etc. unless you see gas droplets from the bike, i wouldny worry about it. sounds normal to me. just check for leakages as a precaution.
RE: Smell of Gas
^^ Are you sure it's gas and not water? When the pipes are cool, then you immediately warm them up with hot exhaust, there is bound to be condensation that spits out the tail pipe. I find it almost impossible that you actually have gas spitting out the tailpipe without it massively backfiring or some other major problems.
And yes, on the 03-06 600RR's, I used to smell like exhaust all the time after riding them. The 03-06 models were notorious for emitting unburned hydrocarbons (earlier 1000RR's included). Those then stuck to your jacket or clothes making it smell like rich-exhaust. I found that if you ride with a leather jacket instead of textile, the smell doesn't stick to you as much. I don't have that minor issue with my 07 though.
It was annoying at first, but eventually you got used to it.
RE: Smell of Gas
i have the same problem with my 02 f4ii smell like rich exhaust when im done ridding i though maybe it had something to do with my high mount. but i also were a textile jacket so maybe that is why i smell it. i just feel like i smell too much like gas/exhaust when im done then i should.
