SIGNALS!
Old Jun 27, 2006 | 07:47 PM
Bake13b's Avatar
Default SIGNALS!
just recently installed the CW fender eliminator on my new 2006 CBR 1000RR yesterday. Ridin today i noticed my right blinker blinkin hella fast. when i checked out the rear one i just put on wasnt blinkin. Does this mean that my wire in the rear slipped out and all that juice is goin to the front? Burnt bulb. I wanna fix it when i get home so i am postin this early. TKS
Old Jun 28, 2006 | 04:03 AM
dragonium25's Avatar
Default RE: SIGNALS!
First of all, the front and rear blinkers are separate, so just because one of them isn't connected properly doesn't mean 'more juice' will go to the other. If you've got LEDs than it's natural that the blink rate will be faster. Are your front blinkers stock or aftermarkets? If your rear isn't working than yes you've probably got a bad connection or no connection at all. Just go back and check your wiring to make sure everything is connected properly on both sides. If you want the blink rate to slow down than you'll need to install some resistors or some sort of flash relay.
Lowridese
May 1, 2010 01:12 AM
platnumbob
Mar 26, 2009 01:16 PM
95cbrmike
Jan 6, 2009 06:38 AM
FaceF4I
Mar 29, 2006 12:41 PM
AEROpace
Jan 25, 2005 04:44 PM
