Shifter problems
Shifter problems
What's up, I'm new to bikes I'm having a problem with my bike it's a 01 f4i it real hard to switch into gears & the shifter pedal is actually getting stuck & isnt dropping back down after shifting it into gear I can't figure out the problem the bike was just riding fine I tried reading other posts I'm guessing it could be a clutch or clutch cable problem! Can anyone give me some insight thanks
Check the clutch cable. It should have about 1/4" to 3/8" of slack. Any more and it
might not be properly dis-engaging the pressure plates, thus making it hard to shift.
If the cable is properly adjusted, you may have a bent shift fork, which will require
much more work to repair. I'm hoping it's just the cable has too much slack.
Good luck, Ern
Good luck, Ern
