Scorpio Alarm help!!
Sorry for brief post I'm frustrated at the forum failure at this moment. Also had to omit words to get it through so it may sound weird
Bought a 02 F4i with Scorpio alarm installed on it. Model i500. I went riding today and it kept chirping at me. Every 3 or 4minutes it would chirp once and blink once. |
RE: Scorpio Alarm help!!
BOTH the blinkers would come on once like hazard on a car.
This damn forum needs to get fixed
Anyone?
Hey there
Sorry I dont know anything about the alarm but maybe it could be some antitheft device where you might have to push a button on the body somewhere like on a car alarm. Might be a dumb response but thought I can just throw in my 2 cents. |
Blinker should flash whenever the alarm is armed or goes off. It will also chirp whenever you remove the connections to the battery and reconnect. You might have a bad ground or hot wire going to the alarm.
well i popped the seat to check on wiring, turns out that the previous owner wired the alarm with electrical tape..so i gotta re-wire everything hopefully that will fix the problem
Yeahprevious did it to the blinkers on mine too. Took it all apart and soldered everything and heat shrunk all connections.
| All times are GMT -5. The time now is 05:34 AM. |
