Rims
Will a rear rim off a F4i fit a F4? My rear rim is bent on my 00 F4 and they want $700 for a new one at the dealership.....can get a F4i rim for $160....
RE: Rims
Not likely as the F4i rim is the same rim off of the 929, therefor wider. Doubtful it will fit, not easily anyway.
RE: Rims
I dont think they will, they are priced differently from the dealership and I did read somewhere that they were wider. Thanks gixxereater. Bought a F4 rim off deadbroke the other day.
RE: Rims
YES...it will fit. BUT...you need the axle and spacers, and the cush drive and sprocket from the F4i rim. The swingarms are exactly the same, and the rims are the same width. But the F4i has a different cush drive and sprocket...lighter...and the axle and spacers are different to compensate for that. The rotor is the same as the F4i, so you could use the one that you already have.
| All times are GMT -5. The time now is 10:05 AM. |
