-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   rev-limiter (https://cbrforum.com/forum/general-tech-9/rev-limiter-51041/)
outontherip Oct 2, 2007 08:01 AM
rev-limiter
how can i lose the rev-limiter on my 07 600rr
thomasintexas Oct 2, 2007 08:36 AM
RE: rev-limiter
the better question is do you really need to?
in 6th @ 13k you would be doing about 180mph right? why do you need to go faster than that?
or have you re-geared for the track and youre just trying to get faster response in 2,3,4?
or should i ask-are we talking the speed limiter that pegs at 130?
Trips Oct 4, 2007 07:33 AM
RE: rev-limiter
With a lot of engines unless you have modified the cams etc there is no benefit to reving higher. Have a look at a lot of dyno graphs and you;ll see the power tapers off before peak RPM
PlayfulGod Oct 4, 2007 08:12 AM
RE: rev-limiter
only if you want to hear a 5k pop when you blow the engine.:D
